Hello everyone. First post here and need some help. I read through a lot of the links that were posted for newbies but I could not find the answer to my question so here I go
I am going to be moving my existing surround setup to another room and I have run across a issue. Here is the current setup. 52 Samsung wall mount with 2 in wall Boston DSi460T2, a Boston center channel, and 2 Boston (forgot the model number)( yes I like Boston) mounted to the ceiling angled down toward the couch and a Boston sub woofer.
I will be moving all of this into a much bigger room toward the front of the house. The dimensions of the room are 18 x 16 and (vaulted ceilings) 14-15 feet. The left and right front Boston speakers are in wall mounts and I can mount those no problem. Same goes for the center and sub woofer. The problem that I am having is in the rear left and right speakers.
Since I have vaulted ceilings I don't want to do ceiling mounts because they would be at different heights. What I am thinking is that I can get another set of wall mounts and mount then in the walls about 1-3 feet behind the seating area. Would this work? Or would the 18 feet be too far?
Sorry for the long winded post. Thanks in advance
Brad
