I have had a re-occuring problem with noise from other electrical devices in my home coming through my speakers. At times when I have the Pro-logic II mode on I hear pops and crackles. It is not a ground loop hum as it is not present all the time.
I have tried everything to correct this including voltage regulators, Line Conditioners and disconecting my subwoofer to no avail. I am running out of things to try. Next I will try a cable coax isolater and see if that works?? The noise is very aggrivating and seems particularly bad at night. I do live in a duplex and share many of the same lines and cable runs as the guy next door. My NAD receiver has a three pronged plug and I already tried a cheater plug which did not work either.
I am convinced this is a grounding problem, as the noise sounds like a very loud pop sometimes and at other times it is just a quieter static noise, similar to the crackling of a dirty record. But it is not constant it only appears intermittently.
I don't know which direction to turn in as I am running out of options. I had heard that some NAD receivers had grounding problems specificaly the new 753 763 773 and I am considering getting rid of my 753.
It is important to understand that It is not a humming ground loop that is constant but a popping or crackling that appears for a split second then re-occurs every minute or so throughout the night.
I have lost handfulls of hair over this problem as I just finished setting up this new H/T system and paid $4000 for something I can't really enjoy to the fullest.
Any help is greatly appreciated.
