LG TV and LG Bluray Issues
E
eng911
I just bought LG 55" 1080p 120Hz LCD HDTV** (55LD520) and the LG Blu-ray Disc Player (BD590C). WhenI hooked everything up at first it worked. Then I tried to switch it to 1080p mode. As soon as I did that I got "No Signal" screensaver on the TV. I called LG and explained the issue. The CSR said it could either be a problem with the TV or the BDP. She suggested I return the BDP and if I still have the problem I will need a TV technician to come to my home.
Back I went to BB and returned the BDP. I brought the new unit home and it had the same problem. I hooked up the composite cables and switched it back. I then swapped the HDMI cable. No change. I started messing with the TV settings. I found I could see the BR video in 1080p only if I changed the TV to RGB and 20Hz. This is not the default for the TV. The default out of the box is 60Hz and YC something something ....
So it;s working after much messing about but does this indicate a problem with the TV? I also noticed the Simplink stuff is not working. Could these issues be cabel related. The cable says HDMI High Speed 1.3b but no mention of CEC.
Any help appreciated. This is my first post so hello everyone.
Tony in Toronto
