I'd like to see how my pre/pro and receivers deal internally with LFE roll-off -- like, if you set some speaker x-over to 80, what does that do to the LFE signal?
Alothough I could use multi channel inputs to get a signal in to the LFE, I'd like to test the electronics in the 'normal' CD/DVD decoding path. I'd need a disc that had bass test tones specifically recorded to decode to the LFE channel -- unless someone has a better way.
Is there such a test disc commercially available?
