MACCA350 is correct, you need to use the analog connections to hear the DVD-A layer. Until you replace your player, however, you can use the digital connection to hear the DTS or Dolby surround layer, which often sounds quite good. Doing this also gives you the ability to use your receiver's DSP which generally allows you more control of the audio. Also, to give yourself the most choices you may want to consider an inexpensive combo unit which can play both DVD-A's and SACD's.
