Could you maybe point out where the Ill-effects of this "resonance" are, and how they make it lesser then the box subwoofer?
http://www.avtalk.co.uk/forum/index....222&rid=0&SQ=0
http://www.avtalk.co.uk/forum/index....224&rid=0&SQ=0
SheepStar
If you have a box sub with 20” walls or s^3 = 8,000in^3 and want the same volume in a cylinder sub:
Let’s say the cylinder was 16” in diameter, then the length would have to be:
V = pi*r^2*h
8000 = 3.14(8^2)*h => h = 40”
The panel resonance of a 20” box sub is: ¼ * 1100 / 1.667 =
165 Hz
If we calculate it for the Cylinder, it’s essentially ½ that since the length is now doubled:
¼ * 1100/3.33 =
82 Hz.
Thus the dominant resonance is right in the passband of the sub. Greater care must be taken to avoid it from becoming audible. Frequency response measurements won’t reveal this, you need to run acccelorameter tests.
Cylinders have more cabinet wall to excite which can result in more diaphragmatic action.
It’s been my experience that many of the cylinder subs (from car audio) use cardboard rather than MDF and aren’t well braced. There are exceptions of course and you can still do a great sub as a cylinder if its done right. At the end of the day, careful design and execution can offset distadvantages of any design. Proper engineering is more important than the actual shape or form of the box.
