Less than 1,000$ Subwoofer options – Suggestions?
mike c
mike c
j_garcia said:
I think that is what a lot of people expect in their bass, and that is why lesser subs do well with the general public - boost and artificial bloat, and the good old 40-50Hz hump. Most people don't know what flat response sounds like. When I heard the DD-15 that was kind of how I felt too, it was great, but I was a little underwhelmed due to the extremely even response. It sounds great for sure, but it just didn't have the impact.
i'm hoping to set the DD to flat for music and bloat on HT :) good thing this has presets.
dentman67
Mike ,
If your running all those subs at the same time you could be getting very negative results . Are the subs all the same model , if not are the subs all tuned at the same freq (not the talking about x-over point)?
If the subs are very diffrent in freq responce you may very well have some cancelation issues going on . One of the worst things you can do (not always but many times) is run subs that are tuned diffrently and share no real common attributes. You can also make these conditions much worse by poorly placeing multiple subs . Multiple subs can sound great but it takes some work and know how .
Forgive me if you know all this , I'm not a regular poster here so I dont know your history .
mike c
mike c
that's ok dentman, I discovered through personal experience how lower level subs can mess up the overall response. I used to test the frequency response using room EQ wizard.
i'm using only 1 or 2 subs on my HT now. I frequently monitor the frequency response so that I do not mess up the overall sound. :)
mike c
mike c
sorry for the thread hijack
so kolia, have you decided on your subwoofer yet?
Kolia
Kolia
Still undecided. I've contacted SVS. I need to hear one.
I visited my local Martin Logan vendor but they didn't have an Abyss in stock for me to take home and test. They did offer to take the Descent though... 3x250W tripple 10in sub. But I didn't want to play with a 3k$ sub. It would just be torture...
The Axiom are interresting too.
Choices choices...
Tetonmtnbiker
Tetonmtnbiker
Stay with Monitor Audio?
Kolia,
You have an all Monitor Audio Silver Series system coming. Have you considered the Monitor Audio RS W12?
Kolia
Kolia
Tetonmtnbiker said:
Kolia,
Going with the RS-W12 was my first idea.
My vendor (who sold me the other RS’) didn’t recommend the Monitor Audio sub. Saying it lacked in musicality and that the amps weren’t quite there. I’ll admit I haven’t tested it myself.
I’m waiting for a Martin Logan Abyss to come in and I’ll take it home for some trials.
Dealers usually try to upsell you, so if they actually admit that it isn't that great then I'd tend to believe it. Unless his next words were "...But this $3K sub sounds wonderful..."
Kolia
Kolia
Yeah, there’s always that fear of being played. At the time, he actually suggested the smaller Martin Logan Dynamo which retails almost half the price of the RS-W12…
I do the up selling myself… Lol
markab1
How about a DIY sub?
Thanks to some really wonderful help I have decided to build my own subs, it may be an option you might want to consider if you have any craftsman type skills at all. I have found that there is 3 to 4 times the value in a DIY Sub vs. a mass manufactured sub and there is a lot of info available in the DIY portions of many AV forums. Imagine, dual 15" subs, capable of 20Hz with 1KW Class G amps for a little over $1000 and the satisfaction of knowing that you built the beasts yourself! Just a great little bit of info a tech sent to me to follow, great advice and technical info about subs. Good luck!
The design of audio subwoofers has, for many years, been predicated on a
theory known as "Hoffman's Iron Law" which provides:
Loudspeaker effiency = volume of enclosure / ( cube of cutoff_frequency)
where cutoff_frequency(F3) is the desired low frequency cutoff or limit for
the subwoofer.
F3 = the frequency where the output drops 3dB (half amplitude)
Unfortunately, because of the physics involved that dictate "Hoffman's Iron
Law," if one wishes to reduce the low frequency cutoff of a subwoofer from,
for example, 50 Hz to 18 Hz while retaining the same efficiency, the volume of
the enclosure must be significantly increased. Or, if one wishes to decrease
box volume from, for example, 1 ft3 to 0.4 ft3 and, at the same time, decrease
the low frequency cutoff from, for example, 50 Hz to 18 Hz, efficiency drops
by a factor of approximately 53.
Consequently, a woofer designer finds that where a 50 watt or 100 watt
amplifier might have operated a 1 ft3 woofer at a 50 Hz low frequency cutoff,
a 0.4 ft3 box at 18 Hz low frequency cutoff will require an amplifier that is
approximately 53 times larger than the first design. In other words, an
amplifier somewhere between 2500 watts and 5300 watts. They would also require
an subwoofer driver able to handle this amount of power without burning up and
without running out of linear excursion. (don't want the voicecoil bottoming
out or being launched into the room) This explains why you will not find any
small subwoofers that can play very deep with any respectable
sound-pressure-level. Basic physics get in the way. This is the reason your
comparing a 600 watt sub with a 1000 watt sub has no meaning at all unless you
compare everything else on how they will perform in your size room.
Today, there are many DVDs with sound-tracks with low-frequency effects down
to 10Hz and lower. Many commercial subwoofers have low frequency cutoffs
somewhere 50 and 100 Hertz and amplifiers around 100 to 200 watts, these subs
don't even come close to reproducing the low bass on these sound-tracks, but
might be fine for music where low-frequency bass seldom goes below 50Hz. Other
subs sold for use in a home theater may have a response down to 20 Hz. These
are usually a bit larger, with larger amplifiers, trading larger size and
efficiency for lower frequency response.
There are many commercial subwoofers that employ amplifiers that are capable
of over 1000 watts. My brother has a small "James" subwoofer that has a 1000
watt amplifier. Again, they traded efficiency for a small enclosure size. It
does very well and reproduces down to 20Hz. The "Sunfire" brand is another
example of a high quality small, inefficient subwoofer.. They use a powerful
2500 watt amplifier in a small enclosure to produce very good quality low
frequency bass. They also traded efficiency for small enclosure size. Does it
play any louder than the "James" subwoofer... probably not.
Most brands of subwoofers have much larger enclosures and much smaller
amplifiers (Most subwoofer "plate-amplifiers" produce from 75 to 250 watts)
So...
Hoffman’s Iron Law says that the efficiency of a woofer is proportional to
cabinet volume multiplied by the cube of the F3. In other words, even though
you want a small box, high efficiency and deep bass, you only get to pick 2...
the third is decided by physics. (Despite what the marketing departments want
you to believe)
If you want a small box, you can have deep bass or high efficiency, not both.
Likewise, if you want deep bass, you get a small box or high efficiency, not
both. Last, if you want high efficiency, you get deep bass or a small box, but
not both.
There is no way to cheat this law until you find a way around the laws of
physics, so it’s something that you need to be aware of when evaluating your
needs, and also when evaluating manufacturer’s sometimes outlandish claims. It
is also what you need to consider when comparing a 600 watt subwoofer with a
1000 watt subwoofer. In reality, the 600 watt sub could go lower and louder
than the 1000 watt sub... it depends on the enclosure size.
How many "watts" do you need for your size room??? I'll say you probably need
somewhere between 50 and 50,000 watts. To reproduce loud low frequency sounds
you need to move (pressurize) lots of air, again physics dictates this. The
larger the room, the larger amount of air your drivers must move to pressurize
it to play at a given db sound level.
For your size room you need either large drivers, or multiple smaller drivers,
and probably drivers with a large XMAX (excursion max) that will displace a
lot of air as their cones move within their excursion limits.
Once you decide how loud you want the sub (in your size room), and how low in
frequency you want it to play, and then pick an enclosure size, you can
determine the size of the amplifier you need based on the efficiency of the
driver. Amplifier power is the LAST thing you should be looking at when
considering commercial subwoofers. In fact, it does not matter at all if the
sub can play the low frequencies you desire at the volume that keeps up with
the other speakers in your theater. Will the "James" subwoofer my brother has
work in your room? Probably not, but in his very small theater it works well.
His room is probably 15x8x8... your room is way bigger and much harder to
pressurize.
Now, do some more research, with your room size and SPL requirements first.
Don't even consider amplifier wattage. If the sub can play as low and as loud
as you require, the wattage required doesn't matter and will vary greatly
based on the subwoofer design.. Building your own subwoofer is fairly easy,
and lots of folks will assist if you take advantage of their experience. All
said, there is no replacement for displacement, so for HT use, go as big as
you can.
Marantz SR8001... Marantz DV7600... BA Lynnfeild VR965's. NHT Classic 3's and NHT Classic 3C
