LCD with Built In DVD Player
  • Thread starter Thread starter ctribble
ctribble
68
0
0
Does anybody know where I can find a 42" LCD with a built-in DVD player? I am doing a job for Wachovia and it has to be 42". If need be...I will have to go with a 42" LCD and buy a seperate DVD player and mount it somehow underneath the t.v. The LCD will be mounted on the wall for presentations etc. So, I will need to mount the dvd player to the wall as well.
Thanks
Ctribble
Toshiba makes them also, though I think their largest is a 37" 37HLV66
Westinghouse does have the 40 with a DVD player. But that is the biggest. And the post above is also correct on Toshiba. 37 inch.
Can you pull mini RGB and have a stand alone DVD player some place?
