jhanley
Hello,
When I play WAV files from my laptop
I use an RCA stereo Y adapter from the headphone jack
on the laptop to the AUX or CD inputs on my receiver.
Am I missing something by not using a soundcard with
digital out, or does this not matter with stero music files?
O
Ohmen
It would seem to me to be the same difference as using the R/L audio outputs of any component rather than the digital output.The DAC inside your computer probably doesn't do as good a job as your receiver. Also there is a high possibility of interference from the laptops components once the signal is converted to analog
jcPanny
jcPanny
Laptop audio output
My dell laptop came with an adapter that plugs into the back to allow access to component video, Analog Audio, and Digital Audio outputs. Check to see if your laptop has something similar.
jhanley
Thanks for the replies!
I never thought of the DAC.
My laptop is audio challenged, with only only headphone
and mic connections.
I guess a USB external soundcard would be a solution.
Thanks again.
mouettus
mouettus
I'm doing the exact same thing with my PC right now and there are no problems what so ever. My soundcard is a pretty cheap old PCI card by the way (SoundBlaster Live! 5.1) I don't hear any noises worth complaining about. But what they say about interference is very true. If you are happy with SQ, then don't bother looking for an external sound card.
O
Ohmen
another option is a media player like the D-link DSM series or any number of other brands and models that are available. The D-link models have become very affordable and would allow you to send the audio to your receiver in a digital format along with the ability to use on screen menu's with your tv to select your songs or playlists.
