kurzweil ks-40a - woofer replacement
Y
yepheeres
hi!
i need to replace one of the woofers on my kurzweil ks-40a active loudspeakers
so far i managed to collect the following specs:
4 inch diameter
antimagnetic
is this enough to guarantee me that i can buy a proper, suitable woofer???
if i order through the kurzweil dealer it costs way too much - its totally not worth it
please recommend a suitable woofer
(and a retailer either in europe or ebay...)
thanks a lot,
mee.point
everettT
everettT
hi!
4 inch diameter
antimagnetic
thanks a lot,
mee.point
Unless you have a specific model number, it's fruitless to even try as it won't work the same. Drop in dosen't work
Y
yepheeres
W0 factory help or a model number, you cant.
i suppose someone else might had the same issue and hopefully they can let me know...
i don't think the factory would be willing to provide such info...
i opened the box but could not find smth more which is rather dissapointing - i hope you understand...
I'd say your choice is largely a replacement driver thru Kurzweil (who I'd not even heard of before) or perhaps now's the time for an upgrade with new speakers. Popping in a different driver as was said is likely not a match (is the dsp of the crossover even user adjustable?), and then you'd need to do both to match them. Matching is more about the t/s parameters than the diameter alone (or anti-magnetic, whatever that means....maybe magnetically shielded?).
