I’m no speaker-internals expert, but I do know that at least some of the relevant components, such as capacitors, their “properties” (sorry, probably not the best word) change with the nominal impedance of the drivers in use. For instance, a cap might filter at 4000 Hz at 4 ohms, and 2000 Hz at 8 ohms.
So – it seems to me like totally removing the load from the crossover (i.e. the driver) is doing nothing good for whatever drivers are left connected. If the crossover frequency is shifted too low, you could end up blowing out tweeters. At the very least it can alter the way the speaker sounds, as often crossovers have components added to tailor response.
Like fmw noted, just let the back drivers fire inside the column. I won’t hurt anything. If you’re worried about them being heard out front, just cover them over with some thick dampening material.
Regards,
Wayne A. Pflughaupt
