Klipsch vs RSL for a 5.1 setup
N
ni317954
Which one would be a better choice for setting up a 5.1 system for mostly watching movies
Klipsch RP 160M pair for fronts for $330
Klipsch RC 62 II for center for $ 150
Klipsch 41M pair for back for $150
RSL speedwoofer 10s $400
OR
RSL CG23 5.1 system with the speedwoofer 10S for 1200$
Budget is ~1200$
hifihillbilly
OR
Budget is ~1200$
I would go with the RSL system. They receive great reviews. You can try them out for 30 days. If you are not satisfied simply send them back.
The one you like the sound of....why those particular choices?
