I had a pair of these on some speaker mounts and after a year or so the mounts must have become loose so both speakers fell and hit the floor smh. Well now one of them sounds distorted. I took it apart and noticed on the woofer where the magnets connect to the basket or frame of the woofer is cracked. I don't know what to use to fix the seal and I'm not even sure if that will fix the problem. Any suggestions on what to use or what could be causing the distortion after it fell? I appreciate any help or advice thanks
