Klipsch RW-12d vs. RSW-10d
JetSnake
Not sure what I'm asking. I mean, how does anyone else really know what "I" want. I was wondering if anyone has any experience with these two subs. I'm trying to pick one that will go with my Klipsch KG5.5's. It's a little more then I wanted to spend, but I think I will go with the RSW-10d.
AVRat
AVRat
I’ve been underwhelmed with the Klipsch subs I’ve heard. For the money you might consider an HSU VTF-3 HO instead.
ParadigmDawg
ParadigmDawg
Tell him about my review on the Klipsh sub AVRat.
sivadselim
Not to speak to the pros and cons of Klipsch subs, but that RSW sub is in a different league than the RW subs.
JetSnake
Oh man, I already ordered a Klipsch RSW-10d. Which Klipsch sub did you have?
I talked to the guy at the dealer, he said he liked the sound quality of the Klipsch subs, so much that you could set the cross over to a higher Hz.
The dealer I was at didn't have the RSW-10d. They had either the RW-12d or the RT-10d. The RSW-10d is right in the middle. I think it should be a little over kill for my Klipsch KG5.5's.
http://klipsch.com/products/details/rsw-10d.aspx
Sivadselim, what was your thoughts on the RSW-10d?
sivadselim
This is a very pertinent question.
Not really sure what this means, exactly. Why would you want to set the subwoofer's crossover setting, either at the sub or with your receiver, higher than is necessary for your speakers? I think what the dealer is hinting at is that the subwoofer performs better than some subs do at higher frequencies. This characteristic is often somewhat erroneously, but not necessarily entirely erroneously, attributed to a subwoofer's percieved "musicality".
It may be in the middle model-wise, price-wise, and power-wise, but it's much closer in both design and implementation to the RT-10d than to the RW-12d.
Probably not overkill. With dual 10" woofers and a low-end F3 of 34Hz, those are some formidable speakers. But the RSW-10d will be fine with them.
I've never heard the RSW-10d, but I have heard all of the older-generation RSW subwoofers (I have an RSW15). The old RSW-10 was a great subwoofer. Very tight, very accurate, and very powerful.
RSW-10 specs:
385watts continuous power, 1150watt peaks
29-120Hz (+/-3dB)
109dB@30Hz, 1/8th space, 1 meter
RSW-10d specs:
500watts continuous power, 1200watt peaks
24-120Hz (+/-3dB)
114dB@30Hz, 1/8th space, 1 meter
On all counts, the new RSW-10d trumps the older RSW-10, so I would expect it to be a great-sounding and great-performing subwoofer.
JetSnake
Greg said he had a Klipsch sub for three days. I was wondering what model it was.
Your right, the KG5.5's rock. Just because they're not the latest and greatest, doesn't mean you can lift your nose at them.
I ordered this sub on-line without being able to listen to it. At a little over $800, I was a little concerned about being satisfied, as that's a lot of money for me. The more reviews I read on this sub, the easier I can rest. It's looking like a winner for me, we'll find out on Wednesday.
ParadigmDawg
ParadigmDawg
I believe it was the RSW-10d but I dont really remember. The bass seemed weak and muddy. It maybe ok for you; I dont know and maybe it was my room. I am just not impressed with anything from Klipsch. I have some RF 62's hooked up right now as my Paradigms are being repaired and I absolutely cant stand the sound of them either. Dont get me wrong; some people like them but they are just not for me. They really hurt my ears.
