When it comes to theaters, the name Klipsch can be found in most movie theaters around the world. With almost 70 years of existence, there is no denying that Klipsch knows how to make exciting audio products to satisfy even the most demanding customers. Now, they are getting ready to release their new Reference Premiere Series of speakers on March 2, 2015. One of these speakers is the new RP-250S Speaker which is a dedicated surround speaker.
This baby features dual 5-1/4" Cerametallic woofers feature a newly developed titanium voice coil former that, according to the company, enhances efficiency, minimizes distortion, and extends low frequency response. Also, Klipsch combined the dual Cerametallic woofers with their newly designed Hybrid Tractrix® horn which, compared to previous Klipsch models, delivers a wider sweet spot. I really like this speaker.
What do you say? Do you like it?
Check out the following features and specifications and tell us what you think!
SOME FEATURES:
- Acoustic suspension (sealed) cabinet design.
- WDST (Wide Dispersion Surround Technology) provides maximum surround coverage and placement flexibility.
- Keyhole slot for easy wall-mounting.
- Durable brushed polymer veneer finish.
SPECIFICATIONS:
- Frequency response: 58-24kHz +/- 3dB
- Sensitivity: 95dB @ 2.83V / 1m
- Power handling (Cont/Peak): 100W/400W
- Impedance: 8 Ohms
- Mid/High frequency driver: Dual 90° x 90° Hybrid Cross-Section Tractrix® horns with 1" LTS (Linear Travel Suspension) titanium diaphragm tweeters.
- Low frequency driver: Two 5-1/4" Cerametallic™ cone woofers with rigid titanium voice coil formers.
- Crossover frequency: 1500Hz
- Enclosure: MDF
- Enclosure type: Sealed
- Inputs: Single Binding Posts.
- Height: 13.5"
- Width: 12"
- Depth: 7.92"
- Weight: 15.7 lbs.
- Finish: Black
Price: $450.00/each.
Click on the thumbnail to zoom in.
