Klipsch R-115SW review?
Serge Lamothe
Hi everyone i have been looking for a Klipsch R-115SW review here and didn't find any?.Anyone knows if there will be a review done in the near future?.Thank you!
shadyJ
Speaker of the House
Staff member
none planned that I know of. Brent Butterworth did a review of the 115SW here. If you want a rough idea of how its performance compares to that of other subs, look at the CEA-2010 measurements in that review and you can use them to compare to other reviews with CEA-2010 measurements, such as ours.
BoredSysAdmin
BoredSysAdmin
Brent compared it to VTF15 mk2 based on price, but realistically even VTF-2 MK5 would be stepping on it's toes at significantly cheaper price. VTF3-MK5 would kill in very low bass, where it's actually matters
Serge Lamothe
Ok..thank you!...
Serge Lamothe
Ok thank you..!
W
Whir1077
Klipsch subs are amazing in my opinion! I have a sw110 and it rumbles very nicely with tight accurate bass. And this is 3 steps below and one class below the reference 115 so I could only imagine.
ATLAudio
ATLAudio
I was going to mention this sub in your other thread to compare to the PB2000. I think they are worth comparing for your situation. Klipsch is actually giving ID subs competition with this model. The benefit here, of course, is you can just go to a Fry's (or similar location) grab it off the shelf the same day, and usually return it no hassle if you aren't satisfied.
Serge Lamothe
Yes ATLAudio i actually just replied to you on my other thread and i will get the Klipsch instead of the SVS.Thank you.
everettT
everettT
Not sure how everyone came to the conclusion that Klipsch subs are awesome, but I know for a fact that apples to apples ID companies crush them, they have one great sub and you will pay for it. Comparing 15" sub to a 12" is dependent on design, and there are quite a few 12s that are up to the challenge easily.
rojo
rojo
Audiophoolery. I agree with @everettT and @BoredSysAdmin . Stop comparing subjectively and instead compare the CEA-2010 data. The Hsu VTF-3 MK5 is about 5dB stronger at 20Hz than the Klipsch. To match the output of the Hsu sub you'd need two of those Klipsch subs.
ATLAudio
ATLAudio
I came to the conclusion that the Klipsch R-115SW was a very good sub for the money. I can't overstate this; this is not inclusive of all Klipsch subs, nor do I think that Klipsch subs are awesome, broadly speaking. That said, this sub, in particular, is perhaps the only retail sub I'd suggest along side ID sub offerings. As far as ID subs that will "crush it" for the same price point, I'm not sure I know of any.
On an aside, the OP is Canadian which complicates an apples to apples pricing comparison, but the Klipsch sub is $720 Amazon Prime US. That makes this sub incredibly competitive against the ID sub market IMO.
ATLAudio
ATLAudio
A sub which is $140 more expensive performs better? I sure hope so. A listener might not need that additional headroom, so no reason to invest in it.
That said, this person inquiring is Canadian so pricing could be crazy. I'm not sure, but he's already ruled out SVS.
rojo
rojo
Sorry, didn't realize he was Canadian. That does tend to make a difference. Grown up subs on a budget are slim pickins up North.
BoredSysAdmin
BoredSysAdmin
A sub which is $140 more expensive performs better. I sure hope so. A listener might not need that additional headroom, so no reason to invest in it.
I got the feeling that your main purpose in life is to spread bs on AH forums. You keep mixing and confusing between price and value, measured performance, accuracy vs headroom.
While you do have point - at current US prices Klipsch is $139 cheaper than VTF3-MK3 (including shipping), but to expect more expensive sub to better (just because it's more expensive) is false assumption.
We are not talking about "more headroom" but about ability to faithfully reproduce very low bass content at more of less same level as low bass and midbass - this will result in sub which is great for music as well as HT.
While Klipsch did made decent effort to try to take on ID subs, but I won't be calling it "incredibly competitive" just yet. Read again rojo said - 5db difference at 20hz is not just minor - this is huge and rojo was underestimated than you'd need two Klipsch subs to match that, in fact you'd likely need 3 or 4. (you'd get +3db if both sub are located on same wall)
Current Klipsch owners Audiovox are hell bend to squeeze every possible cent out of the brands they own and the don't quite give a damn then (not if) they destroy the brand both reputation and quality.
It would take much more serious effort from them to convince me to give them a shot.
Speaking of SVS: PB2000 crushes (in low bass, where it matters) klipsch-r-115sw like a fly and at generally same price point.
PB-2000 CEA 2010 Results (2 meter RMS)
  • 20Hz 103.8 dB
  • 25Hz 107.6 dB
  • 31.5Hz 109.6 dB
  • 40Hz 110.1 dB
  • 50Hz 110.5 dB
  • 63Hz 111.5 dB
Klipsch R-115SW CEA 2010 Results (2 meter RMS)
20 Hz 99.7 dB
25 Hz 104.8 dB
31.5 Hz 109.6 dB L
40 Hz 112.4 dB L
50 Hz 115.7 dB L
63 Hz 114.3 dB L
In addition, I've already mentioned HSU's new VTF-2 MK5. It costs less and is very competitive vs PB2000.
None is relevant since we just learned that OP had double posted and in other one he mentioned that he's from Canada.
I did looked up Sonicboom prices and I was SHOCKED, SHOCKED I am telling you.
http://www.sonicboomaudio.com/box-subwoofers-c-1/nsd-series-c-1_9/svs-pb2000-500-watt-dsp-controlled-12-ported-subwoofer-p-59.html
Converting $1199.99 [CAD] to US dollars is absolutely insane markup of $30 US.
http://www.xe.com/currencyconverter/convert/?Amount=1,119.99&From=CAD&To=USD
It's unthinkable that someone would change THAT much for the effort of importing, shipping, marketing, customer and tech service and last and not least - just pure profit.
shadyJ
Staff member
A couple things to note, BoredSysAdmin: the PB2000 does perform quite a bit better at the low end, but the 115Sw does have more mid bass headroom. The thing is there is a lot more content at mid bass then there is at deep bass, so that is a sensible compromise. However, deep bass output is a lot more difficult of a performance goal, especially at the extremely low distortion levels that SVS targets, so the overall performance of the PB2000 is more admirable, at least for me. Both look like fine subs for the price (well, the sale price for the 115SW).
everettT
everettT
The Canadian factor does skew things a bit, but I'd pay the extra $ to get better performance. SVS CDN is more but I'd rather spend the extra and get the 20 to 60hz advantage. If the OP wanted to do it right he could DIY a creative sound solutions kit and get great results. I'm sure most can do the assembly and if furniture grade cabinet is needed let a local handle that. I understand that the $ to performance ratio might be better there with the Klipsch, I'd still save a little to get more. Without knowing more about the OPs room size and habits , I guess this is all moot.
ATLAudio
ATLAudio
“I got the feeling that your main purpose in life is to spread bs on AH forums.”
IMPO, this is a TOS violation. I don’t know why the insulting behavior, but it seems you are seeking to spin my posts out of context.
“You keep mixing and confusing between price and value, measured performance, accuracy vs headroom. While you do have point - at current US prices Klipsch is $139 cheaper than VTF3-MK3 (including shipping), but to expect more expensive sub to better (just because it's more expensive) is false assumption.”
Who made that assumption? To clarify, I said that if one was suggesting that a particular subwoofer was a better performer than another sub, then I’d certainly hope so since it was $140 more expensive. I edited in more appropriate punctuation for clarity.
“We are not talking about "more headroom” but about ability to faithfully reproduce very low bass content at more of less same level as low bass and midbass - this will result in sub which is great for music as well as HT.”
CEA 2010 illustrates headroom at multiple frequencies. I see nothing in the Klipsch measurements to suggest that it can’t achieve quality music and HT for a $720 sub but that’s largely dependent on room and listener demands. CEA 2010 headroom need not be the same in the low and midbass to accomplish listener demands. No one would buy sealed subs if this were the case.
“While Klipsch did make a decent effort to try to take on ID subs, but I won't be calling it "incredibly competitive" just yet.”
Well, I believe that it is quite competitive at its price point, but you should certainly feel free to disagree. I think that it’s even more competitive when Canadian pricing is involved.
“Read again rojo said - 5db difference at 20hz is not just minor - this is huge and rojo was underestimated than you'd need two Klipsch subs to match that, in fact you'd likely need 3 or 4. (you'd get +3db if both sub are located on same wall)”
This is a great example of my point. Now we are talking headroom at one specific frequency. The buyer might achieve all that he needs with one Klipsch sub, and therefore all of this headroom wouldn’t be needed. I get it, a few years ago, this conversation was about a more expensive retail sub that needed 2-4 times itself to match the cheaper ID sub. Klipsch was guilty of this too, but that was then. You can’t keep using this argument when the better performer is actually more expensive.
“Current Klipsch owners Audiovox are hell bend to squeeze every possible cent out of the brands they own and the don't quite give a damn then (not if) they destroy the brand both reputation and quality.”
I disagree wholeheartedly. Klipsch as a brand is still making great products. I think the fact that since they now have, basically one of, if not the only retail sub from a big name speaker manufacturer in the same value/performance light with ID offerings says a lot.
“Speaking of SVS: PB2000 crushes (in low bass, where it matters) klipsch-r-115sw like a fly and at
Going back to my point earlier, if the Klipsch accomplishes desired low bass demands, then why does low bass get the “where it matters” badge? Customer performance demands are where it matters. Low bass wouldn’t get the “where it matters” badge from the customer if the sub didn’t perform as desired at the mid and higher bass levels.
“generally same price point.”
Not for a Canadian customer.
“None is relevant since we just learned that OP had double posted and in other one he mentioned that he's from Canada.”
I also posted that information on this thread.
ATLAudio
ATLAudio
Good points. But, the SVS might be way out of his budget. Also, he could have tons of room gain waiting on him and never would realize what he spent a premium on.
That’s quite a jump into a DIY suggestion, many don’t have the time tools and or confidence and skill to pull it off. That said I know someone who got burned on the CSS SDX 15 (it was awful, same issues as detailed on Data Bass) also the XBL2 motor is less than efficient. What kit would you suggest?
“Without knowing more about the OPs room size and habits , I guess this is all moot.”
Exactly. I know for me and my main room I’d want more. For my small two channel living room, or exercise room, I might actually demo one from the local Fry’s.
Y
yepimonfire
I would agree they are definitely still making excellent products. Their new lower end reference series sounds better than their synergy and icon series and I would even go as far as to say better than their reference II series, based solely on the fact that they aren't ear piecingly bright and fairly accurate. Their premier series is truly something to behold. Regardless, klipsch still isn't the greatest at making subwoofers, and unlike their speakers their low end response ratings are exaggerated.
I can't remember where I read it but some other reviewer found it to poop out below around 25hz in output. For a driver this size that's not acceptable. The cabinet is just too small for it to be tuned as low as they claim it to be.
3db
3db
So if one is after mid bass performance where a majority of the bass lies, wouldn't you choose the Klipsch over the SVS? You're choice of the SVS as being more admirable has me vexed because you keep mentioning mid bass response as a more important factor.
