i have a pair of klipsch kg 3.2's.does anyone have any idea's what these would be worth.thanks.
I have a PERFECT pair of 1.2's and I paid over $300.00 new, and they are much smaller. 1" horn tweeter, 6 1/2" woofer.
From Klipsch:
Detailed Description
The two-way KG Series KG 3.2 floorstanding loudspeaker was first introduced in 1992 and manufactured by Klipsch until 1994. While no longer in production, KG 3.2 model loudspeakers are still owned and listened to by Klipsch fans around the world as part of two-channel audio and home theater surround sound systems. To connect with other people who are passionate about audio and interested in Klipsch Classic products, visit one the several Klipsch Classic areas on our open forum bulletin board.
KG 3.2 Specifications
frequency response 36Hz-20kHz±3dB
power handling 65 watts maximum continuous (325 watts peak)
sensitivity 94dB @ 1watt/1meter
nominal impedance 8 ohms
tweeter K-84-K 1" (2.54cm) Phenolic dome compression driver
high frequency horn 90°x60° Exponential Horn
woofer K-1002-K 8" (20.32cm) ICG cone active / KD-101-K 10" (25.4cm) ICG cone passive
enclosure material Medium density fiberboard construction (MDF)
enclosure type Bass reflex via passive radiator
dimensions 25.5" (64.8cm) x 12.4" (31.5cm) x 10.75" (27.3cm)
weight 32 lbs. (14.5kg)
finishes Walnut Oil, Oak, Oil, Oak Clear, Finished Black
built from 1992
built until 1994
* Prices are US MSRP and may vary by country.
I would take no less than $300.00 for the pair if in good shape. Those 3.2's were built before Klipsch started making Best Buy junk (As did JBL, etc.) and have REAL veneer finish, not vinyl.
