Klipsch HD 300 on a budget
F
frankieebotz
http://www.bestbuy.com/site/Klipsch+-+HD+Theater+300+5.1-Channel+Home+Theater+Speaker+System+with+Powered+Subwoofer/9388879.p?id=1218096958747&skuId=9388879
So I'm thinking about buying this speaker set. I have read so much about klipsch and it seems to be a favorite on this site. I;m going to use the with a Yamaha V465
Any thoughts? The room is small and I'm in a townhouse, so I'm not looking to blow the roof off. Just looking for a crisp clear sound with solid bass. The speakers I'm using now are really old and I can barly hear anything from the rears.
Thanks
adwilk
adwilk
If this will be used primarily for movies, I think you'll like it and be pretty happy. If you listen to quite a bit of music, i'd look at "The Speaker Company" for your budget or maybe just a 2.1 setup for the time being.
