Klipsch F-3s or F-2s
silversixx
Why should I get one of the other? Since I have the c-2 center and the b-2 bookshelfs (going to use as surrounds) would it be better for me to get the f-2s or the f-3s or does it matter.
Thanks.
astrodon
astrodon
I doubt that you will notice much difference between the Klipsch Synergy F-2 and F-3 speakers. Being an owner of both the Klipsch Synergy line and the Reference IV line let me recommend (if you can afford it) to go with the Ref. IV line and slowly replace all of those Synergy speakers you have with the Ref. IV versions of what you currently have. Then you will definitely notice a difference in the sound.
