I'm strongly considering the following 3.1 Set-Up:
- KEF Q650c Center Channel
- 2 x KEF Q350 for Left/Right
- RSL Speedwoofer 10 sub
- Denon AVR-S750H
The set-up will be in the corner of a newly-finished basement - the ceiling heights are 9 ft (7.5 ft in a small channel for HVAC) and the distance from the TV to the sectional is 15', but there's a lot of space to the left of the seating area with the rest of the basement.
Will the receiver have enough power to run those speakers? I've seen a lot of places quote it at 165W per channel, so it seems like plenty enough, but Denon's spec sheet has it at 75W (8 ohm, 20 Hz - 20 kHz, 0.08% 2ch Drive) and 110W (6 ohm, 1 kHz, 0.7% 2ch Drive) and 165W (6 ohm, 1 kHz, 10% 1ch Drive). The speakers are listed at 8 ohm, min 4.2 ohm. Someone help!
