What's the difference between IQ7 and IQ70? Are they the same speaker?
They are not the same speaker and the iQ70s are superior in their imaging and sound stage. They also have a tad more extension, but not enough to warrant purchasing them over the iQ7s.
I actually suggest you look at iQ5s instead as I think they have better sound overall. While the iQ7s have better extension. The choice is yours, but I think the price difference doesn't justify the improvement. Personally I would recommend the iQ5s first. But it depends on if you prefer extension or better midrange. IMO.
Listening is recommended if you can find them.
Any Kef speaker will give you an idea on the distinct flavor of KEF speakers.
I would suggest buying them and allowing your ears to adjust to the speakers sound. I think some ears have been trained too much on high bass and treble and need to learn the spectrum.
