karaoke Machine to pair with Pioneer LX503?
Hokies83
Wife wants karaoke parties and sees all my speakers and says that will be perfect for karaoke,
So was wondering what’s the Go To Budget Quality karaoke machine that hooks to my receiver ? Thank you :)
WaynePflughaupt
WaynePflughaupt
I’m sure there’s an internet forum dedicated to karaoke enthusiasts. They’ll give you better-informed advice on equipment than you’d typically get at a home theater forum.
Regards,
Wayne A. Pflughaupt
Hokies83
Regards,
Wayne A. Pflughaupt
karaoke Forum may send me to a home audio forum in regards to what works with my receiver :( so was hoping for afew karaoke people here :)
WaynePflughaupt
WaynePflughaupt
You said you wanted one that would hook up to your receiver. Any of them will "work with" a receiver. It's just a matter of hooking it up.
A home system isn't that great for karaoke to start with, because it's easy for a singer to send many systems into clipping. And pray the mic never gets dropped - it'll probably obliterate your speakers.
Regards,
Wayne A. Pflughaupt
Haha. Yes. Karaoke is probably my 2nd favorite hobby behind Home Theater/Audio. :D
I use my RBH SVT towers/RBH SA-500DSP/Denon AVR-5308 in my family room for Karaoke. The secret weapon is the $200 Yamaha Stereo Mixer with COMPRESSION feature from Amazon.
Must have that Compression feature (those YELLOW knobs). That way, even if people do bad things like scream into the Mic, the Volume Level is Reduced and won't Harm your speakers! So the Compression Feature prevents amp CLIPPING and the bad distortion.
The Compression Feature will also raise the volume level so you don't have to scream into the Mic, which is good for people with a weaker vocal.
Here you go. I started a Discussion Thread for Karaoke. :D
B SUBASCHANDRA BOS
Get the POPSICAL unit it even works with sound bar.
I have one and its a well thought out device for karaoke enthusiast.
