lsiberian
If you choose to forgo the recommendations and use a home depot material. Then use fiber glass. They have a 3.5" R11 fiber roll that would work fine. For 10 dollars. It's not as good a rockwool, but it's more than adequate. I do suggest putting burlap over it or putting the paper face out
R19 would work even better for acoustical treatments but it's a little tougher to work with due to it's thickness.
If you double the R11 with the face out on the port wall and use a window brace you'd get an effect like rockwool.
Slight variations in tuning aren't significant but can be tested by modeling the sub in winisd. You need at least a 1db difference in the model before there is a difference and a 3db difference before their is a significant difference. The key is to always start ideal so your variances are within tolerances.
Remember we want to kill the mechanical noise. It's evil and must be destroyed from the sound of your sub.
