JVC,
Thanks for the reply, I do have the manual. Well, I went through it step by step with no luck....I should have read your post before I wasted my time. Here is the problem, on the back of the Dish box was an optical out plug, so I thought "plug it in and get surround sound", wrong. But, why do they have an optical out? For the premium stations that do broadcast in 5.1? In the setup screen for Dish you can choose Dolby. So, I connected the optical out to the TV optical in on the JVC, reassigned that port to DBS, and changed toh input to Analog ..still no sound? So, I plugged the L&R on the Dish out to the TV Audio in on the JVC and that works, in Analog. I still can't figure out why the optical connection doesn't work? One more thing, why can't I pump analog through all 5 speakers?
Thanks again for the reply, if you have any more ideas.............I'm open to suggestions.....
Jim
Dallas, Tx.
