per your recommendation, I went ahead and switched the LFE crossover to 120, it was set at 80Hz, also I changed the fronts to small and the center channel to small, I am not sure where to set up the crossover to the front, center and surround, they are currently set in the following order, Front small 40Hz, Center (small) 40Hz, surround (small) 80Hz, LFE 120Hz, to be honest and I know plenty of you will laugh at this, I am not sure what the Hz do, is lower better, higher better? I am not sure but they do sound cleaner, thank you for the advice, how should I set teh other speakers Hz? sorry for all the Noob questions, you have to start some where.
