Kevin Poirier
Kevin Poirier
Hi to all, I just read that it’s better for sound to install wire jumpers between your binding posts instead of the OEM plate. Is this true?
William Lemmerhirt
William Lemmerhirt
I can’t imagine why? Did the article give any reasons? Got a link?
Kevin Poirier
Kevin Poirier
I was reading SVS Ultra Tower reviews when I came across this (address below). I tried searching and half of the people say they don’t notice a difference but the other half says they notice a difference. Right now I have my towers bi-amped but when I go with the Ultras I’m going to add height channels and will be getting an amp for the towers.
https://positive-feedback.com/Issue67/svs_ultra.htm
Positive Feedback is a wonky site full of audiophoolishness IMO.
William Lemmerhirt
William Lemmerhirt
I actually found the ultra review pretty interesting in asubjective way, and he seems to feel the same way most people do they listen to them. He lost me however, when he typed Nordost, one of the biggest vendors of snake oil today.
What I’d like to know is how the magical jumpers can add any sweet sauce when they both pass through he same internal XO. That’s o big reason “Buy wiring” is a waste.
Fwiw, @Pogre can give you in depth impressions of SVS ultra bookshelf, and tower speakers.
I see a lot of photos with the positive wire on either the lower or upper binding post and the negative on the opposite with jumpers or wires. Makes me crazy! It achieves NOTHING!
Only real reason to swap wire for the included jumpers is to replace a lost/missing one (which is likely only common on used speakers). Other than that, there's no audio benefit to it that I've ever heard of.
Ok. Thank you. What’s your opinion on the SVS Ultras?
Seem to be good speakers from comments I've read, never heard them. I have an older pair of SVS speakers but doubt they have a lot in common outside of the name. Hopefully Pogre will chime in, maybe some others with experience with them....
That is why they are doing it, make you crazy. ;) :D
Kevin Poirier
Kevin Poirier
Thanks. I appreciate it. I hope to hear from @Pogre
Kevin Poirier
Kevin Poirier
Thanks. I appreciate it. I hope to hear from some owners before I drop that much coin.
Pogre
Pogre
I have both the bookshelf and tower speakers. I love the Ultra line. Great speaker/price/performance ratio. As far as buy wiring, I couldn't detect any audible difference with or without the jumpers. I'm running them with the stock jumpers right now.
Kevin Poirier
Kevin Poirier
Thank you. Appreciate it. This helps me a lot
Kevin Poirier
Kevin Poirier
Porge, how do you think the Ultras are compared to Def Tech BP9040?
Pogre
Pogre
I have no clue, I've never heard the 9040. I do know when I replaced my Deftech Studio Monitor 55's with the Ultra Bookshelf speakers I was pretty floored. Much better.
I don't think Deftech make terrible speakers, but they're not my first choice of speaker manufacturer.
