http://forums.audioholics.com/forums/diy-corner-tips-techniques/67396-need-help-box-jl-audio-12w7-3-a.html
Check out the thread link above
t/s parameters(at least what I could find)
Free Air Resonance (Fs): 27.2 Hz
Electrical “Q” (Qes): 0.514
Mechanical “Q” (Qms): 7.807
Total Speaker “Q” (Qts): 0.482
Equivalent Compliance (Vas): 2.33 cu. ft. / 66.0 liters
One-Way, Linear Excursion (Xmax)*: 1.15 in. / 29 mm
Reference Efficiency (no): 0.249%
Efficiency (1W/1m)**: 86.2 dB SPL
Effective Piston Area (Sd): 84 sq. in. / 0.0542 sq. m.
DC Resistance (Re): 2.47 ohm
Nominal Impedance (Znom): 3 ohm
Thermal Power Handling (Pt): 1000W
Driver Displacement: 0.14 cu. ft. / 4.0 liters
Net Weight: 45 lbs. / 20.4 kg
By the equations 118.75 tuned to 22.67 is the optimal alignment with a 6" x 31.35" port
Essentially a 22" cube. You could do a dual 4" but I'm afraid I haven't added the functionality to mess with the ports yet. If you can get the port area to be equal 46.52" with a square port then you can use the length above.
4.65" x 10" square port would work very well
Sealed is 59.51 liters(17" cube)
