Assuming Your Not Just Looking For Validation...
I think you might be missing the point of most of the responses to your original post and questions. Speaker preference generally comes down to a few things, the most important being your own subjective take on their sound reproduction. If you're happy with the way they sound and you're likely to be the main audience, then what ever sound pleases you should be basing your decision on.
Price is, without a doubt, one of the larger deciding factors for consumers when purchasing speakers. Some folks are under the impression that the more they spend, the better the speaker they'll get. While spending a decent amount of money on speakers may likely increase the chances of getting a well built and decent performing product, it won't necessarily give you the best "bang for the buck".
The JBL speakers you reference in the Home Theater Hi-Fi review are solid performers for the money. I think most of the responses here on your thread validate this, however stating that they "may be av123, axiom, svs bookshelfs and RBH" is a bit presumptuous. When performing speaker comparisions from one manufacturer to another, you should be taking into account the type of speaker (e.g. tower, bookshelf, on-wall, etc.), specifications, build quality and last, but not least, price. Two different speaker manufacturers can build an almost identical type of speaker in regards to the cabinet, components (drivers, crossovers, etc.) and even specifications, yet still produce two completely different sounding speakers and may even sell them at a difference in price.
The subjectivity of the listener/consumer will likely dictate whether or not one is more preferrable over the other. Even taking this into consideration, some consumers may be willing to spend more on one over another due to aesthetics, in-room performance and/or their listening material. A blanket statement that one speaker manufacturer's line is better than others is a bit narrow-minded. AV123, Axiom and SVS all offer excellent products for the money, RBH provides some exceptional speakers for their price range, it all depends on what you're looking for.
Another point to kee in mind is that while even a respected source such as 'Secrets' can provide a decent review on these speakers, this is still mainly a subjective viewpoint. While gathering feedback from reliable resources can help in your decision making, listening to as many speakers as you can (in your own listening environment, if possible) that fall within your search criteria will help you find the best solution to your needs... -TD
