Jbl Or Cerwin Vega???? Help Plz!!!!
I
iloveBASS_
hi this all new to me so take it easy yeh. im looking to buy a pair of speakers but im not sure which ones to buy. either the jbl jrx125 or the cerwin vega Clsc-215. yes there both dual 15s i know but im hearing good things about both of them. or even the Cerwin Vega Pro Int 252. im stuck :confused:.
i want to know which ones will have better sound quality and give out more bass. im buyin the behringer ep4000 amp to match speakers. heard that good amp. help me plz :confused::confused::confused:
bandphan
bandphan
Are these for home use?
I
iloveBASS_
yeh sorta. ther b at home all time but outside in this shed sorta fing thats pretty big so room not a problem. but i love my tunes loud n bassy
bandphan
bandphan
Either one, they are both fantastic speakers. Crank em up and get ready to loose your hearing:)
I
iloveBASS_
lol thanx for quick reply and your advice still dont know which pair to get though. jbls a lot cheaper and higher wattage.
I
iloveBASS_
help any1 else?:confused: also do u think i would need an adtional sub for bass? will be having small partys in the summer with family and freinds so loud music will b a must :)
assman3022002
Cerwin vega or JBL
I am the proud owner of Cerwin Vega AT 15's and strongly recommend them! As far as your bass goes depends on your preferance in tunes. Most rock and roll lends itself nicely to the range dynamics possible with cerwin vegas on their own. They actually work as studio loud speakers & entry level industrial power speakers! Dont be fooled these speakers are the real deal. They are well made are fused with a replaceable slow blow system and rarely cut out unless the user weakens them with an amp with not enough head room. So dont cheap out on your amp ( the heart of any system). I went out and got a self powered 15'' 200 watt sub because I could afford it and thought what the hell. I found I really only appreciated the differance added with the sub with Rap music and some soundtrack home theater action movie, Top Gun comes to mind. My neighbours certainly know I have a kick *** System! Wish I could tell you about jbl's I know a band that swears by them! I dont think you will get hurt either way. Likely you will be the new top dog rockin the block! Good luck and turn it up with authority.
I
iloveBASS_
Hi than for your advice buddy helped alot. Well I went and bought a pair of jbl jrx125's and the behringer ep4000 amp. Will be collecting them today. Fancyed the cerwin vega but jbl cheaper and more powerful. And friend of family highly recomends the jbl 1's.
