Jamo A200 HCS5 Satellite Speaker System Overview
  • Thread starter Thread starter HTKamikazee
HTKamikazee
Audioholics Sheriff
Oct 24, 2012
282
0
28
Many people live in apartments and space is an issue most of the time. For nearly two years, and with that in mind, Jamo has been selling their famous A200HCS5 Speaker System.
This system has been designed to be an attractive partner for any flat screen display, with good sound quality. It features 5 identical
curved satellites (model A-200) which are light and slim, so they look neat whether wall-mounted or on a dedicated stand. Each satellite features one 3-inch driver and one 1-inch tweeter.
Check out the following picture to see the opened satellite.
In charge of handling the lower frequencies, this system features the SUB 210 Subwoofer which has a hefty 200W amplifier powering its 8-inch driver. This may not be an audiophile's dream system, but it gets the job done. So, if you are on a budget, or you are limited on space, you might want to look at this system.
SPECIFICATIONS:
  • System Type: 2-way closed
  • Satellite Frequency Response (Hz, +/-3dB): 150Hz - 20Khz
  • Impedance: 6 Ohms
  • Tweeter: 1-inch
  • Woofer: 3-inch
  • Power Handling (Watts Long/Short Term): 80W/100W
  • Sensitivity (dB, 2.8V/1m): 86dB
  • Overall Dimensions (HxWxD): 8.6" x 3.5" x 2"
  • Weight: 1.10 lb.
  • Availability Colors: High-gloss black or white.
Click on the following pictures to zoom in.
