IXOS cable opinions?
jneutron said:
WBT. ...
It must be noted that this approach requires that a mating WBT connector also be used. If not, the shield is re-constituted by the mate connector, spoiling the spillage and returning the connector to its too low impedance.
Cheers, John
Thanks. And that is the problem. Which female in a component is such a match.:eek:
I remember that exchange some time back in your posts almost coming on this design.
jneutron
mtrycrafts said:
Thanks. And that is the problem. Which female in a component is such a match.:eek: .
If a component does not have the WBT female, there will be no impedance match.
Man, your OLD..
Yah, back in the day, huh? I check AR every so often, tis a wasteland..
Hey, I DID create the design..online, I did..independently, it was..(sheesh, I'm soundin like yoda)..course, it was 31 days after they filed the european patent..C'est La vie
Cheers, John
