I must tell you that the implementation of velcro strips is a must! It makes modifications much easier. I originally used wire ties and cable strips. A clean look no doubt, but a 5 star PITA when there was the need to make a change. The velcro strips are much easier to negotiate and takes half the time. Not to mention that with the cable ties, once they are tighten, it's a wrap. You must cut them and then replace with a new one. That's a waste!
Anyway, when it comes to actually following thru on your intention to get back there, you just have to somehow allot several hours and dedicate yourself to the task! Once you start, you have to finish the job if you want to experience the system at full capacity!
or you'll end up with video and no sound or vis~versa, or worst NADA!
I know you are working on the new sub, but what's up with the amp acquisition?! Previously, you said that the wife vetoed the idea. Is the veto still in play or has she softened on her position?!
Regards.
Regards.
