It won't fit - is that stupid?
herbu
First, thanks a ton. Upgraded HT. In large part to the info in this forum, I now have Aperion Verus Grand Towers & Center, Rythmik FV15HP sub, KEF KET3005SE surrounds and HTB2SE 10" 2nd sub.
Gotta say WOW!!!!
Now the weak link is my Yamaha RX-V671 receiver. Although it's new, I don't think it's on par w/ the speakers... so time to upgrade.
I'm thinking the $2k range. The issue is that my entertainment center cabinet is only 19 1/4" deep. Leaving 3" for cables in the rear, that limits the max depth of the receiver to ~16". (I could put the receiver outside of the cabinet, but I've already pushed the boss's tolerance a fair amount.)
My other requirement is true ".2" subwoofer control w/ separate settings due to the huge difference between the 15" Rythmik and 10" KEF.
Between the depth and .2 control, I seem to have knocked out all the top choices except the Denon 4311CI.
However, the good news in my mind is that it seems when you get into this level of receiver, the differences are minor to the casual user. I see a lot of debate over differences that perhaps only a true and knowledgeable audiophile would understand or notice. (Similar to the Brown/Baer/Wilson debates among 1911 aficionados.)
So my question: For a casual user, is it stupid to scratch Onkyo, Yamaha, Marantz off my list simply for the aesthetics of keeping it in the cabinet and/or not having separate control for 2 subs?
Thanks!!
BoredSysAdmin
BoredSysAdmin
Gotta say WOW!!!!
Thanks!!
a) Powering the speakers - your might need a better amp so the solutions are:
Too bad you don't have Pre-out like RX-V667 does have
If you like Yamaha's YPAO system you could get the V667 plus Emotiva XPA-3
Or alternately get a refub one from Ac4l from reputable brand which features full 7.1 pre-outs. Like Onkyo 707/708 or Marantz 6004
b) Sub integration:
New 7.2 Receiver would not cure the issues you have with 2 VERY different subs.
What'cha really need is here:
http://forums.audioholics.com/forums/showpost.php?p=829147&postcount=15
Pyrrho
Pyrrho
I personally would not replace the receiver, unless I could return it for a total refund or unless it could not adequately drive the speakers loud enough.
I was using a $600 receiver with speakers that retailed for more than $6000, and it sounded great. I replaced the receiver with one that retails for $1700 (because I wanted the features), and unless I engage a feature that affects the sound, it sounds the same as the $600 receiver. Now, if my speakers were difficult to drive, it would make more of a difference, as the new receiver can put out about twice the power of the old one, but the old one could cleanly drive my speakers louder than I ever wanted to hear them, so the extra power is completely useless and irrelevant to my sound.
Basically, with any decent amplifier, an amplifier is only going to be a weak link in the chain if it cannot handle the particular speakers you have. There is no way the frequency response or distortion levels of your speakers will ever be as good as your Yamaha receiver, if it is functioning properly and operating within its design limits. And that will be true no matter how much you spend on speakers.
I am not familiar with your speakers and do not know if they are difficult to drive or not.
As BoredSysAdmin says, no receiver is going to make your two very different subwoofers more equal, and so you would be better served by replacing one or both of them instead (again, assuming that the Yamaha can handle driving your speakers).
In almost all cases, if you want an improvement in sound, look to the speakers, keeping in mind that subwoofers are speakers. Or look to speaker placement or room acoustics.
jonnythan
jonnythan
The FV15HP is such a beast I can't imagine that 10" sub doing anything noticeable.
Before you do anything else, I'd suggest picking up a quality measurement microphone and doing some in-room response measurements. First, do some with the 10" sub on and off. I bet you won't see any actual difference.
As others have noted, .2 sub control is really the same as just putting a splitter on a single sub output. It'll do nothing to equalize your subs.
With your system and $2000, I'd get a decent measuring mic and a Denon 2112. Then a second FV15HP ;)
avnetguy
avnetguy
Whether aesthetics are worth it is completely a judgement call as well as the feeling that you need two subs. Spend some time trying to set up just the one sub and see what happens.
If you really feel the need for .2 sub control, one option is to use something like a Behringer DSP1124. You can have many (PEQ) settings options, one for HT, one for music, one for multiple subs or only one, etc and you never have to limit your receiver choice. The only thing is that you need to setup the filters yourself, so a computer running REW and a radshack meter would be required initially for best results. For me, who has a difficult room acoustic wise, the little bit of setup time for the 1124 was well worth it but it was a bit of a learning curve.
Steve
You get 10% off the TOTAL purchase if you get another Rythmik FV15HP.:D
I think the Denon 4311 is 100% awesome, but I think getting 2 identical subwoofers is more important.
So I agree with the recommendation to get another FV15HP.:D
Perhaps use the $1K for the 2nd Rythmik (since 10% off 1st & 2nd sub) and $1K for a new AVR or external amp (since your Yamaha is new)?
Onecall.com has the Denon 4310 for $877:
http://www.amazon.com/gp/offer-listing/B002AKKFQC/ref=dp_olp_used?ie=UTF8&qid=1315497197&sr=8-1&condition=used
It's almost new - LIKE-NEW. And you do get the full brand new warranty. Basically a store display or demo?
The 4310 is not as awesome as the 4311, but the amp section is just as good.
sholling
sholling
According to the specs on those speakers you have about all the power that you really need. Of course more is always nice but they're easy to drive. I agree with the others when they say remove the 10" sub. Stick that sub in your home-office or bedroom or anyplace other than your main room. If one FV15 isn't enough then buy a second FV15.
If you're going to buy a new receiver for a 2 sub system then I'd save up for the Denon AVR-4311 because it has Audyssey MultiEQ XT32.
herbu
Thanks, guys. You got me thinking... and as much as I hate that, it's why I asked.
a) Powering the speakers - you might need a better amp so the solutions are:
This gets to the heart of replacing the receiver. The guy, (really nice guy), at Aperion suggested a better receiver would improve the sound of the Verus Grand Towers before I even bought them. I said ok, that will be my next step, and bought the VGTs and VGC anyway.
To me, they sound great, and the Yamaha has more than enough juice to drive them and the 4 KEFs. (I'm currently running 7.1, w/ the 2 subs simply split w/ a splitter cable.) Normal listening level is -25dB... -10dB for really cool loud HT stuff like The Return of the King... 0dB only when the boss is away as it hurts her ears, scares the cats and dogs, and makes me have to pee. (The FV15HP really is a "beast"!)
So it's not a question of volume. Not really even a question of the .2 separate controls as the Rythmik and KEF have enough controls on them that I think my T-shaped room is fairly well covered now, at least for our 2 seats.
It's really a question of sound quality, which only came up because Aperion said it would make a difference. In fact, they really didn't recommend these speakers with my Yamaha rcvr.
I've seen Pyrrho's sentiment expressed elsewhere... that there really isn't a difference in sound quality as long as you have enough power to drive your speakers. I'd hate to drop another couple grand and find I really can't tell a difference. So I'm still thinking.
Thanks for all the suggestions, guys!!!
...The guy...at Aperion suggested a better receiver would improve the sound of the Verus Grand Towers before I even bought them...It's really a question of sound quality, which only came up because Aperion said it would make a difference. In fact, they really didn't recommend these speakers with my Yamaha rcvr...
I just lost all my respect for Aperion.:eek:
I think the Aperion guy you spoke to is full of crap.
Has he seen the measurements of the Yamaha RX-A1000 in HTM?
Crosstalk is like -93dB, SNR -108dB, THD is like 0.002%. That Aperion guy is an idiot.
BoredSysAdmin
BoredSysAdmin
You'd find very little to no difference in audio quality from switching avrs, except of course to have better auto-tuning system (MultiEq XT) as mentioned before, but no much else other than that.
It looks like you already get sufficient loudness so you're set in that department and do not need external amp, unless you move your speakers (especially mains) to much bigger room
I also agree to others as removing the smaller sub and adding 2nd identical one would help, but before you do that - try to get the best of sub you got, including doing crawling for sub and other optimization as described in AH main site/AV University section
jonnythan
jonnythan
The OP is using a v671, not an A1000.
Well, the Aperion guy did not recommend their speakers with ANY Yamaha AVRs.
My point was Yahama makes some pretty good AVRs, and Yamaha AVRs will sound just as good as Denon, Pioneer, Marantz, etc.
gmichael
gmichael
It looksto me that your receiver should drive those mains with little problem (unless you like super loud music.)
Your mains:
Nominal impedance: 6 ohms
Sensitivity: 92 dB
Recommended power: 20-300 watts
I don't read it that way:
"In fact, they really didn't recommend these speakers with my Yamaha rcvr."
With MY Yamaha rcvr..
Crap.:eek:
I need a break.:D
I just think his Yamaha will do just fine and will sound as great as other $1K AVRs.:D
Of course, as most will agree, the Denon 4311 is top notch. :)
Pyrrho
Pyrrho
There can be a difference in sound if you engage some special feature in one receiver and not the other, or if the features are not implemented in precisely the same way. My newer, more expensive receiver can automatically adjust equalization to make the in-room frequency response flatter, and engaging that affects the sound. But if I run it without such features, and have the settings all the same, it sounds the same. On paper, the more expensive receiver has lower levels of distortion and so forth, but the lesser one is low enough that there isn't any audible problem, and we are talking about levels far below what any speaker would have.
That equalizer function is nice and does, slightly, improve the sound. But my speakers are good and placed reasonably well, so it is not a dramatic improvement.
Now, if you have carefully set up your system, and if you have dealt with any major room acoustic problems, if you want a real change in sound quality, it must be done with speakers. Most people do not spend their money wisely, if maximizing sound quality is the goal. Speakers matter far, far more than anything else. This is because, compared with anything else (well, good digital sources anyway), the speakers are the source of most of your distortion and frequency response issues and other problems. My $6000+ speakers combine to give me a frequency response of about 15-40kHz +/-3dB (excluding room effects), which is really good for speakers, but crap for an amplifier (which should have a much tighter tolerance, and also won't have a frequency response that drops like a brick beyond those limits). And the distortion is something I do not entirely know with my speakers, as speaker manufacturers typically don't give that sort of information, because it is bothersome to measure and mostly because all speakers are crap for distortion compared with any decent amplifier. And also, the amount of distortion a speaker produces is typically related to how loud it is playing, as speakers tend to distort more the closer they are pushed to their limits.
One reason that people misspend their money is that it is easy to see additional features that one receiver has over another, and it is easy to see numbers in power ratings and so forth, and so people want to get a better one. But with good speakers, it is harder to see and point to what it is that makes the one better than the other, at least in many cases. Sure, you can look at frequency response and a few other things like that, but it will not tell you the whole story about which one is better. With the limited specifications that one typically sees, one can easily encounter two speakers with very similar specifications that sound very different from each other, but in such cases, it is hard to point to what it is that makes the one better than the other.
As far as that guy from Aperion is concerned, every company wants to blame any problems with the sound of your system on something else, and he wants you to imagine Aperion speakers are better than they are, and if only you would spend crazy amounts of money on esoteric other gear, you would fully realize the speaker's potential. If he can convince you of that, you are likely to believe you really do hear improvements after replacing other things, as people are very suggestible, and also after making a change, people often listen more intently than they did before the change, so of course they then hear more details than they heard before! (Not to mention the fact that when changing things around, people often slightly reposition their speakers, which can affect the sound by itself.)
Now, if you are not happy with the sound of your system, you should ask yourself what, exactly, it is that you are not happy about. Is it deep bass? If so, then look to your subwoofer situation. Is it clarity of dialog, or an aspect of the sound other than the deep bass? Then it is a question of the relevant speaker(s). If the problem is only when it is playing loud, then it could be either that the speakers distort too much at high volume (which is common enough, and will happen at some point with any speaker, though one hopes to have some such that it will be at a higher volume than one ever needs), or it could be that the amplifier isn't powerful enough for those speakers in that room for the volumes you require. But it is hard to tell which of those it is; one normally "tests" this by replacing one or the other, often by putting in a much more powerful amplifier to see if that satisfactorily deals with the problem.
Most people, though, are just dealing with speakers that are not ultimately satisfying, and so they are constantly trying to do something to get better sound. Well, the solution for them is to get better speakers, which is much easier said than done. Really good speakers usually cost quite a lot of money, and people don't want to face that, hoping that a less expensive option will cure their problem.
If you want your money to go into giving you the best sound you can get, put your money into your speakers, and as little as you reasonably can into the other gear. How little that is depends greatly on the particular speakers selected; I am far less lucky about the needs of the speakers for my main 2 channel system than for my home theater; here is what I use for my main 2 channel system. But even there, I use very ordinary wires and CD player, with a capable but not esoteric amplifier to drive them. They are very "revealing" speakers, and yet they are really the weak link in the chain of my two channel system. Everything hooked up to them has a flatter frequency response and lower levels of distortion. If I used a home theater receiver with them to try to drive them, that would likely be a problem, as they are not efficient and are 3 ohms nominally, and so I need a better than average amplifier to drive them. Even though my speakers are very nice, your "cheap" Yamaha receiver, if used within its design limits, will provide a much flatter frequency response and lower levels of distortion. That will be true no matter what speaker we are talking about.
There is, of course, another issue in audio, and that is the fact that there are some people who are not satisfied, no matter how good their gear is. They have a real problem, but the problem lies in themselves, not in their equipment.
If you have properly set up your equipment, and if you have dealt with any serious room acoustic problems, and if your receiver can adequately drive your speakers, your speakers are the weak link in your system. And it will always be that way, no matter how much money you put into speakers.
herbu
Jonnythan, you're right. Sure apologize for the rift. Aperion didn't talk junk about Yamaha at all... just said my low end $500 model would not get the best out of their Verus Grand line, and could tend to sound a bit "bright".
Lest I leave the wrong impression, I'm very happy w/ Aperion, would go back, and would recommend them to anyone. The VGs are far and away the best sounding speakers I've ever owned, or even heard.
Most of my reading tells me in the $1.5-2k range, the difference in most receivers is in their features, not their quality of sound. If that's true, then picking Denon over Marantz/Onkyo/Yamaha because of cabinet size and Audessy XT32 w/ real .2 is not a stupid call.
Now my new dilemma is if there would really be enough difference in the quality of sound to pack away the Yamaha and drop another $2k on any other receiver. I'm hearing from ya'll, probably not.
Sorry for the confusion. Really, really, really did not intend to discredit Aperion or their guy in any way.
Thanks for all the help!!!
herbu
Pyrrho,
Thanks a million, (or at least $2k), for your time and consideration.
However, PLEASE stop talking to my wife!!!
I still think Aperion is wrong to say that a healthy working $500 AVR will sound bright or will sound bad.
If it sounds bad, then it's the speakers fault, not the AVR.
Great speakers don't make excuses for their sound.:D
But as you have mentioned (I think, since I can't seem to read:D) your Yamaha AVR already sounds pretty darn good with your speakers.
But more features and more power is basically what you get with higher-cost AVRs.
You may also get better build, better aesthetics, more bragging rights, and the knowledge that your AVR is made in Japan, instead of China.:D
