The only component...
...I ever concerned myself with isolating was, and still is, my TT...since it operates by means of vibrations, it makes sense to eliminate outside sources that woud cause mistracking or other mechanical feedback related issues...
Tubed gear MAY become microphonic, but when it does, generally speaking, it's time for new tubes...solid-state devices do not exhibit such tendencies...
Speaker spikes? They help maintain stability of the loudspeakers themselves(particularly on rugs) AND while they do decouple them from potential structure-borne feedback paths, their intent is mostly to improve the performance of the speaker systems; any isolation from other components(such as TTs) while legit, is a mere by-product of the original premise. Nowadays, since few have TTs, isolating other components, as many things audiophilac do, has become a hyped-up "selling point"...and that's how mythology is born.
CDPs??? Yes, they are electro-mechanical...BUT, save for the spindle, there is no real physical contact between software and hardware...unless of course you consider the photons emitted and received by the laser/optical sensor to be "contact" on anything higher than a quantum level...certainly not in terms most would consider as physical...
Take a look at the block diagram for a CDP...error correction doesn't just "happen" in response to outside forces, it is constant, it's always there...it helps keep the arm perpendicular to the tracks. The discs themselves are not perfect...and don't forget playback isn't in real time as it is in analog... CIRC constantly compares and corrects the bitstream...HOWEVER it can't work miracles...if too much data is lost, say due to a solid whack, poof! no signal...some portable players have additional buffers which hold a certain amount of data to help eliminate dropouts for joggers, etc. but they too have limitations...keep whackin' and there is no recovery ability.
SOOO...sandbags, bricks and proprietary combinations of bubinga wood and cryogenically-treated tungsten-steel balls, while possibly have isolating properties, are simply solutions that address non-issues IMHO.
