Bevan
If I have two NAD integrated amps(352's) and a pair of Dynaudio 42's(with only one set of binding posts per speaker), can I bi-amp?
The amps have an extra pair of pre-outs, so if I connect one of the sets of pre-outs to the other amps pre-in, and have one amps left channel powering the left speaker, and the other amps right channel powering the right speaker, is this considered bi-amping?
What will be the gains?? twice the power?
If I can pick up the extra C352(80 watts) for cheap, would this be as/more effective that upgrading to a single more powerfull amp(eg C372 @ 150 watts) which would cost me about the same???
I like the two amp option as it will also allow me run a shotgun 4.1 system if I change the cables each time I change from 2 to 5 channel sources. (I'm guessing that using the remote to controll the volume will increase/decrease it on both amps equally, so if I calibrate using the channel level adjustment on my Denen 2200 universal player I shouldnt have any problems with channel levels. this sound right??)
thanks for help guys
b
b
