David Gaudreau said:
I guess I'll stick with the Optima HD72, Cause I wanted to use a 120" screen, in a completly dark room. I don't think you would see much difference in picture quality would you?
Uhm, that 120" may be fine in a completely dark room: Is that a 16x9 screen or 1.85?
What have you used before? I am using it on a 114", 1.85, 1.5 gain screen at minimum distance of 1.41x width as it places more lumens on the screen, a bunch more, in fact. Plenty bright, a lot brighter than a CRT
And maybe brighter than the 16F-L theater standard that many theaters don't meet, about half, actually.
Unless you watch a lot of movies, lamp costs should be coming down, and, there seems to be just the lamp replacements available too. Sony sells the whole lamp/heatsink assembly.
With the upcoming HD DVD you may want to consider it. AVS has a lot of chat about it.
The only problem is proper calibration as it needs more than the Digital Video Essentials.
Few calibrators out there who have played with it and would not want a first timer to it to calibrate. People do like it a lot
