As seen on kijiji:
Jamo 5-speaker package (S606 HCS3) + Jamo Subwoofer (Sub 200)
Danish Sound Design - A Klipsch Group Brand
Jamo 2x S606 Front Speakers
System - 3-way Bass Reflex
Components - 8" side-mounted Woofer, 2x 5" Midrange, 1" Tweeter
Power - 130W long term power handling
Sensitivity - 89 dB with 2.8V @1m
Frequency Range - 42-20,000 Hz
Crossover Frequencies - 150 / 2,500 Hz
Impedance - 6 ohm
Weight - 51 lbs. each
Dimensions - 42.5" H x 7.5" W x 13.6" D
Features - Black in colour, Removable grill cloths, Equipped for optional bi-wiring/bi-amplification, Floor spikes
Jamo S60 Center Speaker
System - 2-way Bass Reflex
Components - 2x 4" Woofer, 1" Tweeter
Power - 80W long-term power handling
Sensitivity - 87 dB with 2.8V @1m
Frequency Range - 75-20,000 Hz
Crossover Frequency - 2,500 Hz
Impedance - 6 ohm
Weight - 11 lbs.
Dimensions - 5.2" H x 15.7" W x 8.3" D
Jamo 2x S602 Surround Speakers
Components - 4" Woofer, 1" Tweeter
Power - 80W long term power handling
Frequency Range - 80-20,000 Hz
Impedance - 6 ohm
Weight - 7.5 lbs. each
Dimensions - 9.4" H x 5.2" W x 8.3" D
Jamo Sub 200 Subwoofer
System - Bass Reflex
Components - 8" Woofer (bottom-firing)
Power - 200W peak Power Amplifier
Frequency Range - 36-150 Hz
Cutoff Frequency - 40-150 Hz
Impedance - 22K ohm
Weight - 18.5 lbs.
Dimensions - 12" H x 9" W x 17" D
Features - Black in colour, Adjustable phase (0-180 degrees), Level limiter, Manual/Auto on-off power switching
- Purchased new in 2011-Oct from Canada Computers in Ottawa for $800.
- These speakers are in excellent condition with no blemishes.
- I am selling these speakers because I have another complete 5.1 system.
Note: Some A/V receivers will not drive a 6 ohm load. I own an Onkyo model that will.
Note from poster: Does anyone know if this is a good brand? Gibby's electronics is selling this system brand new for 399$ without the sub. Is this a good starter system? And i dont understand what a 6 ohm load is. I have a denon s700w, does that drive a 6 ohm load?
Thank you guys
