Is there such thing as a Blu-Ray shelf system?
Aburtch
Aburtch
I have a small study about 20'x12' and I'm looking to put a shelf system in there hooked up to a 32" HDTV and I'd like a Blu-Ray player. But I can't seem to find a shelf system that has a built in Blu-Ray player.
A stand-alone receiver with speakers and an attached Blu-Ray player is overkill for the room. I was hoping for a shelf system with Blu-Ray, but it doesn't seem to exist.
What shelf system would be good and hook into an HDTV? Then do I buy the Blu-Ray separate and connect that to the shelf system?
Don't necessarily need low-budget system, just something that will fill the room but isn't overkill.
Adam
Adam
There are sound bars with built-in blu-ray players (like the Samsung HT-BD8200). I just did a quick search to make sure that they exist, but they don't seem real numerous.
Is that what you'd like, or do you want something with separate speakers?
BMXTRIX
BMXTRIX
While a shelf system can be nice, if the motorized transport breaks, then the entire system becomes worthless. A small BD player and a small A/V receiver/speakers combo is a far better way to go.
But, if you are set on something smaller, then there are more than a few home theater in a box kits with integrated BD players...
home theater in a box blu-ray - Google Search
From Bose (AVOID!) to GPX ($149!) you can get almost anything in between and the systems can be setup with 5.1 or just a couple of the speakers from the package. These systems truly are designed around surround sound setups, so a stereo setup is kind of against the concept of Blu-ray.
All that said - a 32" TV in a room that is 12' x 20'? That's larger than a lot of people's family room! How far do you intend to sit from this TV? Is it to be used as a secondary room or a primary listening/viewing area?
I've got a nice PC monitor in my study with an integrated BD player, I wouldn't think of putting a BD player into any room in my home which wasn't a somewhat serious viewing environment. The kid's playroom is for games, and they are young (and destructive) so a cheap 32" TV. But the bedroom gets a 52", the family room a 64". Front projection in the basement theater, etc. If you are sitting about 5-7 feet from this TV, then 32" won't do you justice in that space. And, it is a rather large space.
Aburtch
Aburtch
Many thanks! These are all great options.
@BMXTRIX - You are right, 32" is too small, I'm going to go for something bigger with the TV.
@GoFastr - I really like that Yamaha BDX-610 link you sent. That seems to be exactly what I'm looking for.
