bigpow said:
Ok, so maybe I got it backward then?
If the speakers are low end, then I'd need a high-end receiver?
Uh, no, not really. Like I said, price is not indicative of much besides quality (usually).
Things to look for when considering what amp you need;
- Speaker sensitivity rating; usually given in dB's for 1 watt measured at 1m - these days most are between 87 and 91dB although there others higher, like the Kipsch and some are lower, like the SVS.
- Speaker impedance; most home speakers are nominally 8 ohm, which means that's the average of its impedance curve - it may drop much lower at some points. 4 ohm is also relatively common - a 4 ohm load requires 2x as much power (watts) to drive them all else being equal.
- Room size and how far you'll be sitting from the speakers. The further away, the more power you'll need - you lose 6dB for every doubling of the distance between you and the speakers, so that 85dB@1m will be 79dB at 2m and 73 at 4.
- How loud you want to listen - most people consider 90dB to be very loud. My lawn mower is rated at 89dB and I wouldn't want that in my living room. A rock concert is about 110dB+.
- Peaks - you have to take into account transient peaks (like explosions) that will exceed the ambient sound level and make sure your amp gives some head room to cope with them. 3dB is the
minimum headroom you should have but considering that ambient levels may double with transients, you'll need 10x the power as that being used for ambient levels. So, if you're listening quite loud and using 10watts and along comes a large transient, doubling the sound level, you'll need 100watts.
bigpow said:
Is that why Klipsch speakers are popular (need less amp to drive them?)
Some, maybe, but Klipsch have a distinctive sound that's very dynamic - some people like that.
bigpow said:
Thanks for the link to "Buying Guide".
BTW, if I just want a receiver to drive SBS-01 set without any fancy features (just enough wattage, DD or DTS, don't need HDMI etc) - then this 2600 is beginning to look like an overkill...
"Fancy" is a relative term now isn't it?
