Is my screen too big???
just-some-guy
just-some-guy
Have you considered a 2.35:1 screen? You can go wider without having to have a lot of height and the experience is incredible. I'll never do 16x9 again.
it really depends on the room/wall size. but basically, 16x9 is best up to a certain size (depends on the room). then 2:35 takes over.
K
kiwiaudionut
Your setup is very close to my own, though i don't have that unfortunate bulkhead to deal with. The one thing that stuck out to me was your intended projector mounting position. The bottom of the projector looks as though it would be knocking a few heads! I have a 7'9" ceiling height and intend to mount the projector as high as possible in the back of my room to give the most head clearance i can. Is it possible you could do the same? Max throw from the lense to the screen is about 20' i think for the 8700.
Give the increased distance, i bet the projection beam would miss the bulkhead !
Mad-Max
Mad-Max
hmmmm 20' projection...may be a good solution to the height issue...going to look into that.
Thx
As for my accountant well I just better not say anything...lol
