Hi, I'm new to posting here but have found the boards quite helpful in setting up some new systems in my apartment. Now I have a problem that I'm not able to solve myself and I was wondering if anyone had any ideas.
My place came with a bunch of audio-related multi-room wiring already in place. This included a wall sensor in the kitchen to extend the IR signals from the living room stereo. I purchased the Niles repeater hub, on the assumption that it would be compatible with the sensor but now I find the connections seem to be different. The hub has a 4-wire cat 5 connection and the sensor only has space for 3 wires (only 2 of which were connected when i pulled the sensor out of the wall). The cable has 4 wires in it but it doesn't look anything like cat 5, it looks more like thin-gauge 4 lead speaker wire. I can always get a new Nile sensor that will work with the hub, but now i'm worried that the wire won't work. Is anyone aware of an IR sensor that uses 3 wires -- and not cat 5? What's going on here?
Thanks in advance to anyone who can help.
Nick
P.S. I just discovered that the cable in the wall is "Belden Non-Paired - Audio, Control and Instrumentation Cable" -- if that means anything to anyone!
