Interesting Speaker Shapes
Sheep
Sheep
Clint DeBoer said:
That looks like a restaurant high chair with a couple conga drums on top...
Ugh! I hate babies at restaurants.
"Waaa, waaaa"
"SHUT UP"
"WA-SHUT UP"
"RAHHH"
Oh Family Guy, what would I do without you.
SheepStar
kingdaddy
kingdaddy
You win!!
That’s actually the most common comment I get, bongos/congas. My new center channel looks more like bongos then these.
Fastnbulbous
Fastnbulbous
Check out the description. That's some funny ****.
First, please try listening 16cm full-range speaker system SP-8716 of our company. You understand the sound that is near the original sound, and the large floor-type speaker system was developed on the special order for those who wish a further near the original sound. Box vibration, horn vibration, and division vibration of vibration element were complete to eliminated. As a result, there be not the excessive sound other than a music signal and approached limitlessly the original sound. In a multi-way speaker system, you have to combine the image of sound position of each speaker unit. If you do not combine the image of sound position each speaker unit is heard in pieces. Furthermore, sound pressure of each unit is not able to combine the right level. If the image of sound position is combined, each unit becomes one sound source, and the presence of the speaker system will be lost and it will become a natural sound. The sound is natural and without the vice, and so becomes the personality sound of the equipment that are using the all stage. Depending on usage, the theory of an old audio may be reversed fundamentally. The evaluation in the time that did a first audition thinks that it is inevitable to feel with the sound that there is not force furthermore and unsatisfying sound. As for this system, all of a woofer-box and attached parts are made from the carbon plate and the carbon block. Furthermore, since special processing of the cone paper has been carried out, 38cm woofer sounds to the same sound as the full range speaker. It is a fact although it thinks that many persons cannot understand this phenomenon.​
I'm guessing the writer's first language is Russian. "Women desire to be carnal with us, because we create the most premium speakers of its quality and class with a natural sound however without the vices..."
AndrewLyles
Fure said:
Here is a interesting speaker manufacturer. I saw this company in a catalog from a local hi-fi shop. They had three models listed stating from 17,500 to 52,000 a pair. I can only imagine what this setup would cost. :D
http://www.avantgarde-usa.com/basshorns.html
That bass horn only reproduces sound dwon to 18Hz. Tell me again, why that seems incredible when regular subwoofers go significantly lower than that? I nmean other than the fact I could in in that thing.
