That sure does say something!
In all honesty, I am pretty happy with my F113 setup. While I know I'm missing a lot of subsonics, I still have quite the visceral experience at home, particularly when on the riser, and IMHO it's comparable in tactile feel with the local IMAX. Yet, the knowledge that I'm missing subsonics leads me to the Tuba, hehe. When I did choose my sub back when, I did so for the SQ (was mated with electrostats), and with good looks and diminutive size in mind for the LR. This was way before a lot of current day choices were available, including the PB13s.
Here is my main worry: The only place for the Tuba is behind all of the seating. Since bass is omni-directional, this shouldn't matter I suppose? My present sub is placed on the sidewall, about 1/3 from front wall, in front of viewers. While the mains are crossed at 60hz, all others are at 80hz.
Assuming you tell me that behind all viewers is perfectly fine, I suppose you would also say that the Dayton driver you are using is the best present fit for that build, and that even the most modest of pro amps will be enough to fill my entire home and then some?
Thanks.
