Wow, the install is tentatively done. I tied up the cables with velcro and twist ties so I can swap out or re-route any cables as necessary. The layout remained the same as the picture above but the router and modems are on the top shelf and the phone is on the shelf with the PS3. What a pain in the tush, adding the networking stuff into the main system. The sheer number of 9v and 12v adapters is simply crazy.
And why won't somebody make a 6" LAN cable for a router and modem that sit right next to each other.
Impressions:
The GUI is light years ahead of my Denon. Really, it's beautiful looking, well laid out and easy to use.
My SD channels have never had such a nice, clean image. GO REON!!! YOU ROCK!!!
I didn't hook up the Algolith Flea in the setup this go around because of the Reon chip and I am not disappointed. Although in the few minutes I've had to play with setting, the image is better with the HDMI output to pass-through instead of having the DTC do the de-interlacing from the Sat box's 1080i signal. The 1080p output from the DTC was significantly grainier than the pass-through setting.
I'll have to pick ADK's brain for using the sound field settings properly.
Other than that, it's 4AM, my wife is sleeping and I won't be able to do the auto-setup, Audessey or run bass sweeps for the sub's new location front and center with the center channel on top for a little while.
Grade so far - A+++
