I've got an Infocus X1 which I just hooked up after four years of not using it. I can't get it to select a HDMI signal from my Dish Network Box source. I went online and upgraded the firmware to 4.3 and I bought a 25 ft HDMI cable and an HDMI to VGA adapter cable...still nothing! I don't get it. The last time I used it with Dish Network was before I upgraded to HD...and it used to select the source signal just fine...thought maybe I needed some HDMI cables or something, but Nooo! It still selects the DVD and VHS signals. I'm stumped! Anybody know what I'm missing here? Do I need a converter or switch box or something to convert the HDMI signal to a VGA format or ???? My X1 manual says it should work with 1080i and 720P if the connection is a VGA, however, the Dish Box does not have a VGA connection on it so, I am using the HDMI out with a cable connected to a VGA adapter to the projector...with no luck! (Photo of the connection to the projector below) Thanks a bunch for any help!
