Column II's
Well....I picked the Column II's today and I'm pleased to say the least!
When I got home I immediately hooked them up and they sound great. All the speakers appear to be functioning. They do sound different (as in a bit brighter...perhaps the two tweeters?) as opposed to my SM-152's.
They do need some work:
new grille cloth
crossover updates? caps?
tweeter in the back of one speaker has come loose
one woofer is missing a dustcap
case needs to be cleaned (someone put a coat of shellac on the cases...yes, shellac)
Does anyone know how the original finish should appear?
Was the color light or dark?
I'm thinking about refinishing them with a walnut stain. I've done quite a bit of refinishing so this is a task I can handle.
This is my first speaker restoration so any advice (as in lessons learned) would be appreciated.
Thanks in advance!
