Incompatible audio signal
CyClones
I just found this tidbit, I have a Sharp LCD as well going through an Onxyo and also get the same error ... Shaw HDtv Cable Box-->Onkyo Receiver..Sound set to output to Surround sound speakers.. I am also getting the error but in my case I do not have the TV speakers enabled .. ..During a little research I found this and will try it later when I get home.. and let you know the outcome
PROBLEM: INCOMPATIBLE AUDIO SIGNAL
All my A/V devices (360, PS3, Wii, Samsung DTB-H260F) were connected to my Onkyo TX-SR607 receiver with HDMI, which was set to output to my Sharp Aquos LC-52E77U. And, although the receiver was set to "Audio TV Out" off (and even with it on), the TV kept popping up this error:
"Incompatible audio signal has been received, please check the output signal."
It only pops up for a few seconds, and only when I would switch devices or resolution or whatever. Still, pretty annoying. Connecting the devices directly to the TV via HDMI caused the same error - the only time it didn't happen is when there was 2ch 44.1/48Khz PCM involved.
Unfortunately, unlike every other TV I have ever owned, the Sharp doesn't have a menu option to disable audio. Muting didn't help, either.
The solution? Set the audio volume to 0. No more error!
CyClones
I turned down the volume on my Sharp lcd to zero. :note:not mute .. but turned it down to zero and this corrected the error message .. yea!!!!
Adam
Adam
Welcome to the forum, and thanks for the info on that! I'm glad that it worked for you.
