In need of suggestion on how to piece-meal together a system!
settle010
I have recently aquired a set of panasonic speakers from someone moving out for free and am in need of some suggestions on what would be my cheapest route of getting these to work.
After looking at the speakers for a while. I realized that the speakers are a part of a "theatre-in-a-box" system. This system is a Panasonic SC-PT750. From this set, I have the following items:
Subwoofer (SB-HW750), 2 Front Speakers (SB-HF750), 2 Rear/Side Speakers (SB-HS750), a center speaker (SB-HC750), an Ipod Dock, and a wireless system (SE-FX65).
I am looking for an amp or a receiver that would be cheap and that would work with all the components listed above.
Also perferrably one that would have 2 if not 3 HDMI inports as well.
Let me know what ya'll would suggest!
Thanks
BoredSysAdmin
BoredSysAdmin
I could rec you to get something like new Onkyo TX-SR308 with MSRP of $300, but then all your speakers with central all-in unit cost same I don't think this would be good advice.
Better choice would to go used/refub:
http://www.accessories4less.com/make-a-store/item/ONKTXSR307BLK/Onkyo/Tx-sr307-5.1-channel-Home-Theater-Receiver/1.html
for $160 with 1 year warranty is what you need..
However I won't expect much of SQ out this system - i checked out it's specs and they are very underwhelming .... Probably could work in small room at best, if properly placed.
btw: Forget about wireless system and ipod docl, without central unit they're useless.
settle010
Next Move
Do you think it would be worth my while to attempt to sell the parts from my current system that I previously listed online. I have been looking around and thinking I could make around $50 for the Ipod Cradle alone and $100 for the S-Air System. Do you think that I would be able to make any sort of money from the speakers and/or sub? I know that these are not real useful for me at this point, but do you think that they could be useful for anyone else, such as a Panasonic system owner?
