Hi All, I need two in-ceiling speakers for my living room setup. They will be the two rear channels in a 5.1 system, and will serve double-duty for movies and music. I'd like them to be good enough to hold their own in All Channel stereo mode but reviews of in-ceiling speakers in general are all over the map. I'm looking to spend $200/each max and have been reading about the following options:
1. Paradigm H65 (local shop rec)
2. Klipsch CDT 2650 (local shop rec)
3. RSL 34E (Lots of good forum reviews)
Are these at all comparable? Is there one you think would be a clear winner? The RSL's are $125/each while the others are $200/each. Are there other speakers you'd recommend instead? B&W etc.
Thank you!
