jcPanny
In-ceiling speakers
Brazoo,
I wouldn't bother with a box for the entry level polk in-ceiling speakers. You should also consider the in-wall speakers for your Main L/C/R channels and a full 7.1 system. Your HT speakers will have a crossover with a sub to handle the bass. Consider some extra wiring so you can add a sub to the bar location also to improve the bass performance. I would also recommend a volume control for remote locations like the bar."
I agree with what you wrote on the vol control in the bar area which I am know planning. Here is what I am using for the front L & R in the system - Polk RC65i and in the front center channel I plan to use Polk Audio CSi3 Center Channel Speaker. All 3 rears will be the RCi60's in ceiling. I wanted to place one set in the left wall at a 90 degree to my couch but would not have a wall to do a 2nd on the right and with small kids under age 3 I was in no way going to have a floor tower they could pull over etc. So I opted for the 3 front and rears and will add a sub. Was considering the Polk Audio PSW404 10-Inch 200-Watt Powered Subwoofer, Black as my choice (yet to be purchased)
TLS Guy - Just got off the phone with Polk and like you said they are meant to be open and the specs are unpublished but he did tell me that if I did the enclosure or needed to that 1 1/2 ft of cu space total would be needed.
I am leaning to open based on all this and all your help. I will place a 2X4 on the side to keep the r-19 insulation off them but leave the tops open to the subfloor above.
Thanks to all for your help - Brazoo
